06-10-2020 02:15 AM
The current of these three power(MGTAVCC MGTAVTT MGTAVCCAUXT) supplies is not mentioned in the datasheet. Where can I find it? KINTEX 325T or 160T
06-10-2020 03:27 AM
hi @ackye ,
Please once the under the section PCB Design Checklist of the https://www.xilinx.com/support/documentation/user_guides/ug482_7Series_GTP_Transceivers.pdf
06-10-2020 10:49 AM
Kintex-7 is an FPGA as such power will scale with size/speed/voltage or the GT logic used. As such you can either quickly estimate power via XPE linked below or via Vivado with a example design if you need a slightly more accurate figure but it will take a little longer to get to. I recommend reviewing UG
https://www.xilinx.com/products/technology/power/xpe.html
T
