shruthi_07
Where to look for Speed and Area after running Behavioral Simulation?
Hello all,
I ran my Verilog module, and was looking into TCL Console for Speed and Area measurement for my design.
I found that "launch_simulation: Time (s):...." results were not a constant value for each run.
If this is not the place to look for Speech and Area determination, where should I look for them?
Please help.
Thank you.
Shruthi Sampathkumar.
balkris
Behavioral simulation only guide for functional correctness . To get areas and speed/timing information . You need to synthesis and implement the design .
Check the synthesis and implementation reports for details
This guide may help you
http://www.xilinx.com/support/documentation/sw_manuals/xilinx2016_2/ug888-vivado-design-flows-overview-tutorial.pdf
Hope it will help you
Thanks and Regards
Balkrishan
balkris
Thanks and Regards
Balkrishan
