xxy012600
Whether the DisplayPort IP support to train to the computer when the computer is using windows XP or not?
LogiCORE DisplayPort Receiver v7.0 (Rev. 1) - XAPP1178 -Why does the DisplayPort RX driver for the
DisplayPort IP fail to train to the host computer when the host computer is using windows XP ? When using DisplayPort IP to link the host computer of using
windows XP can not output 4K resolution,the DisplayPort IP display "training lost".
But that is Successful to train to the host computer when the computer using windows 7,the host computer can output 4K resolution,the DisplayPort IP display "training
done".Whether the DisplayPort IP support to train to the host computer when the computer is using windows XP or not?How do I resolve displayport can not connect
to the host computer that install windows xp?
balkris
XP is not supported version for Vivado 2016.1 and for this xapp.
Please use supported versions
Thanks and Regards
Balkrishan
xxy012600
thank you!But I want to ask Whether the DisplayPort IP support to train to the computer when the computer is using windows XP or not,rather than Microsoft Windows support the vivado version.
