Observer @yj
Which software can convert pictures into hexadecimal data.
    I search answers in community forum,but I failed. So I want to ask for help .The details like the below pictue.
Re: Which software can convert pictures into hexadecimal data.
Hi @yj
Please check this link:
https://www.mathworks.com/matlabcentral/fileexchange/34713-imagetohex-hextoimage-cconversion
Rohit
Scholar u4223374
I don't know of any program that can output the required format directly. Irfanview doing an ASCII PPM output would be close, but it doesn't provide the commas.
However, it's a very simple program to write in Matlab/Java/Python.
Hi @yj
Rohit
Observer @yj
    Thanks very much.
Observer @yj
   Sorry I don't know what you're trying to say.
@yj You can use opencv for such conversion
https://stackoverflow.com/questions/50272801/convert-an-image-to-value-hex-code-for-example-with-opencv-and-python
But if you wanna make it hardware level than you need to user ARM core I guess, as onl reVision has opencv support
Observer @yj
     Thanks .By  the way  ,do you know how to use a camera in ZC706 board. The only way to use the camera in the board is insert the camera in the FMC ?  If so ,whether there have a universe FMC connector that suit more components to connect the board.
Observer @yj
I want to ask a more question .Do you know how to use a camera in ZC706 board. The only way to use the camera in the board is insert the camera in the FMC ? If so ,whether there have a universe FMC connector that suit more components to connect the board.
