Why my app_rdy signal is kept low permanently in the middle of the process?
Hello all,
I'm working on a DDR3 project, and I'm using a MIG to generate a memory controller. The software is Vivado 2014.2, the FPGA model is V7 (xc7vx485tffg1927-2).
Everyting works fine in the simulation, the MIG can read all the data out successfully. However, the reading process
stucks and the 'app_rdy' signal is pulled down permanently while I'm running my code on the board using chipscope as you can see in the screenshots.
Re: Why my app_rdy signal is kept low permanently in the middle of the process?
@derickshi, MIG does not suport timing simulations, so we do not recommend that flow.
If the IP works fine in simulation I would recommend to cross check if your board has any issue.
Please use Xilinx standalone example design and see if it behave the same way.
Double check all the basic things like power, terminations, clocking and reset.
When app_rdy went low permanently probe your board to confirm if DQS is togging
Hope this helps
-Vanitha
Hi @derickshi,
Are you using post-implementation timing simulation?
If not please verify the output of post-implementation timing simulation.
Arpan
Arpan
I'll try it, thanks!
Hope this helps
-Vanitha
Observer ssummerq
Have you solved the problem? I meet the problem like this .Thank you very much!
