Observer tollinjose
Working of IBUFDS
I no longer require IBUFDS since signal are going to be inside fpga. How can i replace this? Is there any document where I can see timing diagram of IBUFDS? Or can somebody tell me what is the functional equivalent of IBUFDS.
Re: Working of IBUFDS
@tollinjose
i want to know logic value of output will be equivalent to which input pin I or IB?
Check Page#279 from UG953  for the Logic Table. Its applicable to all IBUFDS across families.
- Giri
Community Manager
Community Manager
Sorry I dont understand the question, you no longer require an IBUFDS, because the signal you are inputting is a single ended signal versus a differential signal?
I don't have a timing diagram to share but it you do a test case with timing constraints (set_input_delay in Vivado or OFFSET_IN in ISE) you can see the delay through the IBUFDS it will merely be a delay.
Observer tollinjose
@tollinjose
- Giri
for differential clock signal IBUFDS is okay  and For differential data's (data_p[15:0] and data_n[15:0]) How to use Buffer? How to get data from differential signal? I attached file simulaiton result using IBUFDS for differential clock and data.
