jab3
XADC OT Shutdown - Priority of Enables
In the Series 7 (specifically, Zynq-7000), it looks like there are at least three ways to enable OT (over temperature) shutdown:
  1. Setting the LSBs of OT Upper Alarm register to "0011".
  2. Clearing bit 0 of the XADC Config Reg 1.
  3. Setting BITSTREAM.CONFIG.OVERTEMPPOWERDOWN to ENABLE.
How are these combined?  Do they all need to be true to enable OT shutdown?
Is there any way to determine (from a configured device) whether (3) is true?  E.g., will it prevent XADC Config Reg 1, bit 0 from being set to '1'?
klumsde
Hi @jab3
All 3 steps need to be taken to enable the OT shutdown.
As far as I'm aware there is no way to tell if the bitstream option is set.
Keith
klumsde
Hi @jab3
Keith
jab3
So, just to explicitly state the situation I was hinting at, if BITSTREAM.CONFIG.OVERTEMPPOWERDOWN is set to DISABLE, then:
  1. The settings in (1) and (2) above are non-functional.
  2. There is no way to detect this condition, other than reading back the bitstream and manually parsing it to see whether the config bit is set.
What about the XADC_OVER_TEMP bit in the Configuration Status Register (bit 17)?  It's listed in the register table in UG470, but the description is omitted.  Does this show the value of the config bit, or the state of the OT alarm?
