Observer himanshu28
XADC constraints and I/O
I am using XADC in DRP mode and Vp-Vn channels for taking input. While doing the I/O planning the Vp-Vn ports take the value L10 and K9.
The question is where do I connect my wires so that I can supply input to XADC as I cant find any ports with these numbers. Will connnecting my wires to JA XADC header help because thet have different port numbers (eg. N15-N16).
Please help with the above issue.
Re: XADC constraints and I/O
Hi @himanshu28
Use Vaux[6], Vaux[7], Vaux[14] or Vaux[15]. These have the connection to XADC_PMODCapture3.PNG
Reply, Give kudos and accept as solution
Hi @himanshu28
As I can see there is no electrical connection from dedicate Vp_0 and Vn_0 pins to the XADC PMOD connector.Capture.PNG
I believe your objective here is to monitor the external analog inputs, then you can use the auxiliary inputs which have electrical connection to XADC PMOD i.e below inputs
 Reply if you have any queries, Give Kudos and accept as solution
Observer himanshu28
Thanks for the reply.
But I have same problem with the auxilary pins as they take a package value that is different from the PMOD port values.
Here I have used vaux[0] pins for taking input and they take the values B20 and C20 in the package pin which are HDMI pins.
Hi @himanshu28
Observer himanshu28
Thank you very much. Using the vaux[14] pins solved the issue.
But I have a doubt regarding other pins. If they are not electrically connected to the PS bank then how can they be used .
For example the vaux[2] pins were connected to b20 and c20 pins on bank 35 which are mentioned as HDMI ports. What are the use of these (apart from vaux 6,7,14,15) pins in XADC?
