geetha.diwakar
XADC enable/disable
If i disable the xadc,cant i use system monitoring for zynq?
let me know.
thank you.
@geetha.diwakar
According to UG908 (on about page 95), the Zynq-7000 SYSMON reports FPGA voltages and temperatures that have been measured by the XADC.
For Zynq Ultrascale FGPAs, the XADC is referred to as the SYSMON (see Table 1-1 of UG580 for details).
So, whether you call it the XADC or the SYSMON, if you power it down then you will not receive System Monitor measurements of FPGA voltages and temperatures.
Cheers,
Mark
