XADC output is incorrect until I start the Vivado Hardware Manager
I'm working with an XADC and reading the most significant byte from it's output word. The resolution looks incorrect. It ranges only from 0x3A to 0x3F.  If I fire up the hardware manager however, everything works as it should. So my question is, what exactly is happening to the XADC when the XADC system monitor starts?  Because whatever it it seems to be fixing my problem...
Here's a video showing the issue:
https://www.youtube.com/watch?v=vxrqPcMaPY0&feature=youtu.be
Thanks!
-Adam
Re: XADC output is incorrect until I start the Vivado Hardware Manager
Bump for any assistance. Thanks!
Hi @ajcrm125
Sorry to see no one has replied...
So how is your XADC set up? What mode is it in? What channel is this?
Is it external input and if so how is it set up is it a ubipolar or bipolar?
0x3F0 is only about 250mV on the unipolar scale,is there any reason why the analog input would sit there?
Is the FPGA always configured? The hw manager opening should have no impact on the XADC really.
Why are you reading the Most Significant Byte only?
How do you read it? Do you use the driver that comes with the XADC and print over UART?
cheers,
Keith
Hi Keith,
Thanks for the reply.  See comments below...
Interface Selected: DRP
XADC operaring mode: channel_sequencer
AXI4Stream Interface: false
Timing Mode: Continuous
DCLK Freq: 24Mhz
Sequencer Mode:  Continuous
Channel Averaging: None
Enable External Mux: false
What mode is it in?
Channel sequencer mode
vauxp3
External unipolar input. vauxn3 is tied to GND.
Nope none that I can think of. The POT connected to the analog input is grounded when I fire up the design.
Yes a microcontroller on the board programs the FPGA and logic within the FPGA design reads values from the XADC and sends them over to the micro continuously via the SPI bus.
When the hw manager opens up it doesn't do anything to the XADC via the XADC jtag DRP interface?
The Z80 softcore is an 8bit CPU and he's the guy that's making use of the data.
How do you read it?
I have a small FSM that sends read instructions through the DRP interface.
No the terminal you saw in the video was from the microcontroller's UART. The XADC data is sent from the FPGA to the  micro and printed from there.
Is there any time requirement between when reset deasserts on the XADC and when the user can start issuing read instructions?  I was messing with the FSM to add states to read initial values from the config regs and noticed that all of a sudden the issue went away.  Still experimenting but it seems if I add a delay of a few cycles between reset and DRP reads the output looks correct.
I can't say for sure.
I would expect that the fsm should be waiting on eoc +the channel_out value corresponding to vaux3 before trying to read a result.
I was going to suggest taking a look at the jtag locked pin but I don't think that is the issue it seems more like you have some issue around it coming out of reset.
It's hard to say when you I'm not familiar with your design
What other channels are you converting in the sequence?
What is your DCLK divide?
