Visitor armature
XC6SLX9-TQG144BIV1229
please i need your support reggarding below:
I have XC6SLX9 is mounted on ESS ethernet smooth stepper CNC controller i got it from warp9td
i had overvoltage issue on the main power supply so please  how to make sure the microcontroller is ok?
in case need to replace the microcontroller please advice what if there is a new ording number for below microcontroller?
because i can't find complete information in the selection guide
SPARTAN-6
XC6SLX9
TQG144BIV1229
D4429868A
2C
attached
- microcontroller picture
- selection guide
- ESS
- start up video
thanks a lot
best regards
Re: XC6SLX9-TQG144BIV1229
Generic way might be checking is the Chip/IC is heated or not while you power up it for small duration of time. If have then it might have issues. You may check the VCC/GND and other signal of Spartan 6 IC and identify. Xilinx people might suggest you on the debugging!
While , if you need to replace the existing chip by new Spartan 6 FPGA chip , you need to have bitstream or program for the board again. Is the board/system design by yourself? Basically FPGA is re-configurable chip, it doesn't have program while purchasing new, so you need to develop the program called "bitstream" for it to work. And for uploading the program the board must have the programming interface or port as JTAG/USB.
krishna@logictronix.com
Visitor armature
Dear krishna
thanks so much for your answer
yes Chip/IC is heated
could you please guide me how to check the VCC/GND and other signal?
this is CNC control board and it's designed by Warp9 Tech Design
Visitor armature
Scholar u4223374
You can buy a replacement Spartan 6 here. However, if the voltage spike was enough to destroy that, it's also quite possible (likely, in fact) that some or all of the other components have been destroyed too. I suspect that the cheapest option here is going to be to buy a whole new board.
