XC7K160T-2FF676I lead content (ref. QC2122F)
Can you please advise if the XC7K160T-2FF676I uses lead in the solder only, or is it used elsewhere?
I can see that it is not RoHS compliant.
Thank you
Tom
QC2122F
tenzinc
Check package mdds for that sort of info. Yes, "FF" package will have lead in their solder bumps and balls. "FFG" is the lead free variant so if you want a RoHS compliant part then that's the one for you. See both mdds links below:
FF676 MDDS:
https://www.xilinx.com/support/documentation/package_specs/pk193_ff676.pdf
FF"G"676 MDDS:
https://www.xilinx.com/support/documentation/package_specs/pk548_ffg676.pdf
T
