manumohanmm
XC7Z020-1CLG484I Powe estimator
I am using Xilinx 7000 series SoC for my new design.
Part number : XC7Z020-2CLG484I
I have downloaded the XPE for 7 series device power estimation
But i couldn't find out 2CLG484I device in the XPE.
How i can estimate the power using this tool ?
kkn
have you enabled the security warning?
I was able to select the device which you have mentioned
gnarahar
@manumohanmm
Make sure you have the latest XPE version 2016.1. http://www.xilinx.com/products/technology/power/xpe.html
As kkn mentioned above, select Industrial grade and then you should see the -2 option.
- Giri
If starting with Versal take a look at our Versal Design Process Hub and our Versal Blogs
