XSysMon VS XAdcPs
Hello everyone,
as you can see in the subject. Can someone explain me the differences between XSysMon and XAdcPs?
When should I use what, and what are the positives and negatives?
thanks and greetings
Re: XSysMon VS XAdcPs
Xsysmon is used for the PL side xadc or sysmon xadcps is for the ps sysmon in us+
I'll double check but you should see it in the BSP
Hi @klumsde
But if I use XAdcPs-functions they have totally the same functionality as the XSysMon-functions.
So your answer is not so clear for me
when you make a BSP in Zynq what gets pulled in as the driver?
