narahari
Xilinx Kintex 7 , 7045 equivalent without ARM
Hi I need a Xilinx device which is equivalent of 7045 but without the ARM A9, and other IPs
i.e FPGA which can hold 5.2Million gates
 what is the FPGA device name ?
regards
narahari
balkris
Kintex-7 doesn't have any ARM core . ZYNQ family only have ARM core
Check the resource guides here
http://www.xilinx.com/products/silicon-devices/fpga.html
http://www.xilinx.com/support/documentation/selection-guides/7-series-product-selection-guide.pdf
http://www.xilinx.com/support/documentation/selection-guides/low-end-portfolio-product-selection-guide.pdf
Thanks and Regards
Balkrishan
u4223374
Advisor
Advisor
There's no direct comparison. The XC7K325T is a bit smaller; the XC7K355T is a bit bigger.
pratham
@narahari As said in the previous post there is no direct replacement but you can consider xc7k355t as this would be more than enough.
-Pratham
