ZYNQ7Z030 Power Banks
I need to know about voltages for the following banks. In which document I can find this information.
Bank 12
Bank 13
Bank 33
Bank 34
Bank 35
MIO 500
MIO 501
MIO 502
Re: ZYNQ7Z030 Power Banks
Hi @peterjohn ,
@peterjohn wrote:
The part number is ZYNQ7Z030_FFG676.
This means
Bank 12 - HR - 3.3 V
Bank 13 - HR - 3.3 V
Bank 33 - HP - 1.8 V
Bank 34 - HP - 1.8 V
Bank 35 - HP - 1.8 V
MIO 500 - 3.3 V
MIO 501 - 3.3 V
MIO 502 - 3.3 V
No, your understanding is incorrect.
For HR Banks you can provide VCC Voltage levels : 1.14V to 3.465V.
For HP banks you can provide VCC Voltage levels : 1.14V to 1.89 V.
For MIO Banks you can provide VCC Voltage levels : 1.17V to 3.465V.
Based on the IO standards you choose for the Pins present in that corresponding Bank, you need to provide VCC Voltage for that particular Bank.
For example : If I declare LVCMOS33 IO standard for 4 pins of Bank12 (HR Bank). Then I need to provide 3.3V VCC Voltage for Bank12.
Note : When combining different IO standards in same bank, you need to abide by rules given in page 97 of UG471 (v1.10).
Deepak D N
Please Kudo and Accept as a Solution, If it helps.
Hi @peterjohn ,
For Bank 12,13,33,34 and 35 banks. To know Bank in HR or HP refer ASCII Pinout File of corresponding Full Part number of FPGA. For more information on ASCII pinout file refer page 27 of UG865(v1.8.1).
Bank.PNG For more information of above image refer page 3 of DS191 (v1.18.1).
Hope this helps.
Deepak D N
This means
MIO 500 - 3.3 V
MIO 501 - 3.3 V
MIO 502 - 3.3 V
Hi @peterjohn ,
This means
MIO 500 - 3.3 V
MIO 501 - 3.3 V
MIO 502 - 3.3 V
Deepak D N
