Partha_Das
Zynq-700(ZC-702) board motor control
Hello All,
I am trying to run motor control using zynq-7000 AP SOC (ZC-702 evaluation kit).
However, I am unable to find any document which will help me to start the project.
Can you please provide me any link for the following documents or any starting procedure for the following tasks.
1. PWM generation using zynq-7000.
2. Electric signal like voltage, current, encoder signal sensing using zynq-7000.
3. Inverter control using ZYNQ-7000.
Please help to to get started.
Thanks in advance.
katsuki
Hi @Partha_Das
Zynq-7000 has a built-in ADC.
System Monitor and XADC.
UG480 - 7 Series FPGAs and Zynq-7000 SoC XADC Dual 12-Bit 1 MSPS Analog-to-Digital Converter User Guide
For ZC702, please refer below.
UG850 - ZC702 Evaluation Board for the Zynq-7000 XC7Z020 SoC User Guide
Thank you.
Don't forget to Reply, Kudo, and Accept as Solution.
Don’t forget to reply, kudo, and accept as solution. If starting with Versal take a look at our Versal Design Process Hub and our Versal Blogs
katsuki
Hi @Partha_Das
For Motor Control, our partners offer solutions. There are related links on the following site, so please have a look.
Drives & Motor Control → Smarter Control
Thank you.
Partha_Das
Hi Katsuki.
Thank you for reply.
Is it possible to provide any link where we can find analog signal sensing of ZC-702 board.
Thanks in advance
katsuki
Hi @Partha_Das
Thank you.
katsuki
Hi @Partha_Das
I've provided some information, if already issue has resolved, Kudo, and Accept as Solution.
If you want to repeat a new question, please post a new one.
Thank you.
