joe306
Zynq 7000 Power Supplies: Single Output Switichers or Multi-output Switchers
Hello, quick question for the forum members and has to do with choosing between individual switching regulators for the Zynq power rails or use a multi-phase output switching regulator?  Can anyone share their opinions please? Which is easier for the PCB layout designer?
Thank you
bruce_karaffa
Like everything else, it depends.  I have a couple designs using the Analog Devices LTM4644.  Four outputs with independent enables and power good signals to make sequencing easy.  Being a small BGA part, it gets crowded under the chip so layout takes a bit more work here, but it is compact if you need to save space.
I also used a design copied from the ZCU-102 and the TI LMZ3150x series of parts.  You can get higher power outputs.  Bigger pads and more surface area per watt makes thermal a little easier.
General impression.  If you are crowded and have fairly modest requirements, try multi-output.  If this is a big power hungry design, think about individual converters.
bruce_karaffa
joe306
Hello, this is perfect. I used the LTM4644 on a TI ARM+DSP design. I'll look at the LMZ part you referenced.
Thank you very much.
joe306
Just wanted to say that Enpirion EN6326 and Renesas ISL8203 are good supplies too. Very cool running chips and good efficiency.
Respectfully,
Joe
