manumohanmm
Zynq 7000 series IO's default status
I am using ZYNQ series XC7Z020-2CLG484I SoC for my new design.
How to control the default status of selected I/Os to low.
I know I could able to make it high or 3-stated by PUDC_B pin.
gnarahar
@manumohanmm Below snippet from Page#49 of UG471  http://www.xilinx.com/support/documentation/user_guides/ug471_7Series_SelectIO.pdf
- Giri
If starting with Versal take a look at our Versal Design Process Hub and our Versal Blogs
umamahe
Some more additional information:-
If you follow power-up sequence as per data sheet then IO state is in high-Z during power-up condition.
During configuration the default IO state depends upon PUDC_B pin input state. When PUDC_B is High, internal pull-up resistors are disabled on each SelectIO pin. So if you put external pull-down resister and your PUDC_B is High then you will get default low output during configuration.
