about CLOCK OUTPUT PINS
I'm using ARTIX 7  XC7A75T-2FG484I  FPGA.
this FPGA doesn't have dedicated CLOCK OUTPUT  pins, so can i use IO pins as clock output pins.
Manu H M
回复: about CLOCK OUTPUT PINS
Hi manu.hmdbit@gmail.com
You can use Clock Forwarding as p128, in ug471:
https://www.xilinx.com/support/documentation/user_guides/ug471_7Series_SelectIO.pdf
Simon
manu.hmdbit@gmail.com Hi
Just reminder, using the ODDR to output clock outside the FPGA, or you will get a error from tool's report.
