fogl
changing clock input pin position
I am having problem with modification of my design. I changed the clock input pin position from first MRCC input (located at the corner of the die) to the second MRCC input (located in the middle of the die). The "new" design fails timing at several paths (Intra-Clock - setup).
Is this typical that the design is so sensitive regarding the clock placement - I was expecting better results with the clock pin located at the middle of the die?
Klemen
hpoetzl
Voyager
Voyager
Hey Klemen,
Thank you for your reply,
You're welcome!
How can i reset the design?
In the 'Design Runs' tab, there is a 'Reset Runs' button and context menu option.
So if i am close to the design margins, i can probably expect some problems later, if i change something.
Correct.
I am running the design at 100 MHz - i assume this is not critical frequency.
No for 7Series the critical limit starts at 240MHz and goes up to 500MHz depending on what you are doing.
Of course, you can still hit critical timing problems way below that or just have too strict constraints.
Hope this helps,
Herbert
-------------- Yes, I do this for fun!
hpoetzl
Voyager
Voyager
Hey Klemen,
Is this typical that the design is so sensitive regarding the clock placement?
Really depends on the design.
If you are operating at the limits of the FPGA, the slightest change can tip you over the edge.
That said, did you place and route from scratch or did you reuse the existing placement?
Best,
Herbert
fogl
I run Synthesis and Implementation after the constraint change. I thought Vivado starts all over again, not from some previous design step. How can i reset the design?
So if i am close to the design margins, i can probably expect some problems later, if i change something. I am running the design at 100 MHz - i assume this is not critical frequency.
Klemen
hpoetzl
Voyager
Voyager
Hey Klemen,
You're welcome!
Correct.
Hope this helps,
Herbert
fogl
Thank you for your comment. I did try to Reset Runs and the result was the same.
So it seems i will have to modify the design.
Klemen
