clk wizard always miss locked
hardware zynq_7020
software --vivado2018.2
ip  clock wizard6.0
input  25mhz,rstn
output 10mhz,locked
cconfig :mmcm  freq syn,phase aligh,safe starup, mini power ,balanced
question: when i monitor lock signal ,i found that locked signal is periodic signal, its periodic is about 92us,and lower level is about 18.44us,and rstn signal is normal, what's wrong?
ps when i simulate,it does not happen,but when i download bit doc to soc ,it appear.
Re: clk wizard always miss locked
The first place to look is the input clock.
The datasheet will tell you that the maximum allowed input jitter is 20% of the i out clock period or 1ns max.
What does the clock you provide look like. Try a simple build with no mmcm and route the incoming clock to a pin and scope it.
Another test for the input clock quality is change the output frequency to if it will lock with different settings.
If the clock is good then the next place to look is the power supplies. Is vccint noise causing too much jitter on the clock path or indeed the feedback path?
Next look at vccaux is that noisy is it outside the recommended tolerance on the rail?
Next simplify the mmcm.
Get rid of the safe start up option and the minimize power option see if it works then.
Have you tried a reset? Reset the mmcm and see if it locks.
Can you share the M, D, and O values set by the wizard?
