kynthia9
compile_simlib error in 14.3
compile_simlib -simulator ncsim
Compiling libraries for 'ies' in '/user/nak/work/pcie_gen3/axi_bridge/managed_ip_project/managed_ip_project.cache/compile_simlib'
Library verilog.secureip:verilog.axi_bfm will not be compiled, because precompiled library info is up to date.
Library verilog.secureip will not be compiled, because precompiled library info is up to date.
compile_simlib[verilog.secureip]: 0 error(s), 0 warning(s), 25.00 % complete
Library vhdl.unisim will be compiled, because precompiled library info is stale.
--> Compiling 'vhdl.unisim' library...
> Source Library = '/vl/edatools/extern/Xilinx/Vivado/2014.3/data/vhdl/src/unisims'
> Compiled Path = '/user/nak/work/pcie_gen3/axi_bridge/managed_ip_project/managed_ip_project.cache/compile_simlib/unisim'
> Log File = '/user/nak/work/pcie_gen3/axi_bridge/managed_ip_project/managed_ip_project.cache/compile_simlib/unisim/.cxl.vhdl.unisim.unisim.lin64.log'
Library vhdl.unisim:vhdl.unimacro will be compiled, because precompiled library info is stale.
--> Compiling 'vhdl.unisim:vhdl.unimacro' library...
> Source Library = '/vl/edatools/extern/Xilinx/Vivado/2014.3/data/vhdl/src/unimacro'
> Compiled Path = '/user/nak/work/pcie_gen3/axi_bridge/managed_ip_project/managed_ip_project.cache/compile_simlib/unimacro'
> Log File = '/user/nak/work/pcie_gen3/axi_bridge/managed_ip_project/managed_ip_project.cache/compile_simlib/unimacro/.cxl.vhdl.unimacro.unimacro.lin64.log'
compile_simlib[vhdl.unisim:vhdl.unimacro]: 1 error(s), 0 warning(s)
INFO: Please refer to the messages between 'BEGIN_COMPILATION_MESSAGES(ies:vhdl:unimacro)' and 'END_COMPILATION_MESSAGES(ies:vhdl:unimacro)' in the log file compile_simlib.log for details of compilation error(s).
Library vhdl.unisim:vhdl.unifast will be compiled, because precompiled library info is stale.
--> Compiling 'vhdl.unisim:vhdl.unifast' library...
> Source Library = '/vl/edatools/extern/Xilinx/Vivado/2014.3/data/vhdl/src/unifast'
> Compiled Path = '/user/nak/work/pcie_gen3/axi_bridge/managed_ip_project/managed_ip_project.cache/compile_simlib/unifast'
> Log File = '/user/nak/work/pcie_gen3/axi_bridge/managed_ip_project/managed_ip_project.cache/compile_simlib/unifast/.cxl.vhdl.unifast.unifast.lin64.log'
compile_simlib[vhdl.unisim:vhdl.unifast]: 1 error(s), 0 warning(s)
INFO: Please refer to the messages between 'BEGIN_COMPILATION_MESSAGES(ies:vhdl:unifast)' and 'END_COMPILATION_MESSAGES(ies:vhdl:unifast)' in the log file compile_simlib.log for details of compilation error(s).
compile_simlib[vhdl.unisim]: 3 error(s), 0 warning(s), 50.00 % complete
Please refer to the messages between 'BEGIN_COMPILATION_MESSAGES(ies:vhdl:unisim)' and 'END_COMPILATION_MESSAGES(ies:vhdl:unisim)' in the log file compile_simlib.log for details of compilation error(s).
Library verilog.unisim:verilog.unimacro will not be compiled, because precompiled library info is up to date.
Library verilog.unisim:verilog.unifast will not be compiled, because precompiled library info is up to date.
Library verilog.unisim will not be compiled, because precompiled library info is up to date.
compile_simlib[verilog.unisim]: 0 error(s), 0 warning(s), 75.00 % complete
Library verilog.simprim will not be compiled, because precompiled library info is up to date.
compile_simlib[verilog.simprim]: 0 error(s), 0 warning(s), 100.00 % complete
Copying setup file 'cds.lib' to '/user/nak/work/pcie_gen3/axi_bridge/managed_ip_project/managed_ip_project.cache/compile_simlib/cds.lib' ...
* COMPILATION SUMMARY *
* Simulator used: ies *
* Compiled on: Wed Oct 29 16:43:35 2014 *
* Library | Lang | Mapped Name(s) | Err#(s)     | Warn#(s) *
* unisim | vhdl | unisim                       | 3               | 0 *
* unimacro | vhdl | unimacro             | 1               | 0 *
* unifast | vhdl | unifast                       | 1               | 0 *
ERROR: [Vivado 12-3591] compile_simlib failed to compile for ies with 5 errors.
ERROR: [Common 17-39] 'compile_simlib' failed due to earlier errors.
and the log file says:
ncvhdl(64): 12.20-s016: (c) Copyright 1995-2013 Cadence Design Systems, Inc.
ncvhdl_p: *F,NOLSTD: logical library name STD must be mapped to a design library [11.2].
how to solve this problem?
yashp
This looks like version mismatch issue.
Vivado 2014.3 supports IES 13.20.005 and above version.
Please check the compatibility,
Yash
yashp
Yash
kynthia9
when i update the version of INCISIV to 14.1 and restart gui window of vivado 14.3, use same command, then i have this info displayed:
compile_simlib -simulator ies -directory /user/nak/work/compxlib/
ERROR: [Vivado 12-3754] Failed to find the 'ies' simulator executable. Make sure to set the 'ies' installation environment and retry this command to compile the libraries for this simulator. For more information on tool setup refer 'ies' user guide.
Library compilation for 'ies' ignored.
kynthia9
i give the wrong INCISIV PATCH number. now solved.
kynthia9
sorry, too early to say solved, still comback with errors.
ncvhdl(64): 14.10-g041: (c) Copyright 1995-2014 Cadence Design Systems, DEBUG
DEFINE unimacro /user/nak/work/compxlib//unimacro
ncvhdl: *W,DLCPTH (./cds.lib,1): cds.lib Invalid path '/user/nak/work/compxlib/unimacro' (cds.lib command ignored).
DEFINE unifast /user/nak/work/compxlib//unifast
ncvhdl: *W,DLCPTH (./cds.lib,2): cds.lib Invalid path '/user/nak/work/compxlib/unifast' (cds.lib command ignored).
DEFINE unisims_ver /user/nak/work/compxlib//unisims_ver
ncvhdl: *W,DLCPTH (./cds.lib,3): cds.lib Invalid path '/user/nak/work/compxlib/unisims_ver' (cds.lib command ignored).
DEFINE unimacro_ver /user/nak/work/compxlib//unimacro_ver
ncvhdl: *W,DLCPTH (./cds.lib,4): cds.lib Invalid path '/user/nak/work/compxlib/unimacro_ver' (cds.lib command ignored).
DEFINE unifast_ver /user/nak/work/compxlib//unifast_ver
ncvhdl: *W,DLCPTH (./cds.lib,5): cds.lib Invalid path '/user/nak/work/compxlib/unifast_ver' (cds.lib command ignored).
DEFINE simprims_ver /user/nak/work/compxlib//simprims_ver
ncvhdl: *W,DLCPTH (./cds.lib,6): cds.lib Invalid path '/user/nak/work/compxlib/simprims_ver' (cds.lib command ignored).
ncvhdl_p: *W,DLCPTH (./cds.lib,1): cds.lib Invalid path '/user/nak/work/compxlib/unimacro' (cds.lib command ignored).
ncvhdl_p: *W,DLCPTH (./cds.lib,2): cds.lib Invalid path '/user/nak/work/compxlib/unifast' (cds.lib command ignored).
ncvhdl_p: *W,DLCPTH (./cds.lib,3): cds.lib Invalid path '/user/nak/work/compxlib/unisims_ver' (cds.lib command ignored).
ncvhdl_p: *W,DLCPTH (./cds.lib,4): cds.lib Invalid path '/user/nak/work/compxlib/unimacro_ver' (cds.lib command ignored).
ncvhdl_p: *W,DLCPTH (./cds.lib,5): cds.lib Invalid path '/user/nak/work/compxlib/unifast_ver' (cds.lib command ignored).
ncvhdl_p: *W,DLCPTH (./cds.lib,6): cds.lib Invalid path '/user/nak/work/compxlib/simprims_ver' (cds.lib command ignored).
kynthia9
using 14.1-g041 version.
yashp
Now its look like IES issue.
Can you please check with them?
Yash
