ronnywebers
Advisor
Advisor
configuring MIO pins of SDIO interface 'slow' vs 'fast'
I'm wondering if the SDIO interface pins in the Zynq IP config dialog should be set 'slow' or 'fast'? I'm using a 50MHz SD clock :
Picozed board def file  sets it to 'slow' :
but Zedboard for example sets these to 'fast' ..
Q : which setting is recommended for SD-card interfacing, and what exactly is the difference between 'fast' and 'slow', does this setting configure a different driver on the I/O pin?
klumsde
I would normally make the clock have the fast slew rate. the other outputs can be slow slew rate.
in practice there is not very much in the difference.
a very simple IBIS simulation will show you
klumsde
