dds dithering
hi ,as iam including a psuedo random sequence generator ,in the dds code ,i took a function of dither and wrote a codeo prn sequence of 18 bits.but iam getting the errors as shown
Dear farhathsuj,
you could use a procedure instead of a function and pass the clk and the reset as arguments. As far as I know, you can't use signals in a function. But I usually try to avoid functions all together, cuz using them removes a lot of control over the synthesis process (like e.g. inserting pipeline registers etc.). Except ofc for generating LUT tables or the like, which is something the compiler does during elaboration.
The best way would be to use a process, cuz all ur function does is implementing a shift register.
Best regards,
Martin
Dear farhathsuj,
Best regards,
Martin
