driveDone does not report correctly in bitgen log for Vivado 2014.x and 2015.2
Very minor bug to report here on the text output of bitgen for Vivado 2014.x and 2015.2 for drive done...
Step 1. Turn on DriveDone
set_property BITSTREAM.CONFIG.DRIVEDONE Yes [current_design]
Step 2. Run bitgen
write_bitstream $verbose_flag                -force $bitOut
Design behaves as expected
Step 3. Log file does not
| DONEPIN                 | PULLUP*                 |
-m
Re: driveDone does not report correctly in bitgen log for Vivado 2014.x and 2015.2
hi,
it looks DriveDone was removed from bitgen options based off this link.
http://www.xilinx.com/support/answers/44103.html
can you confirm if it was seen in the bitgen report earlier?
--hs
@maxbaker
This property shouldnt be used with 7 series devices. This property is not visiable to customers hence shouldnt be reported in reports tools is doing correct job.
report_property [current_design ]
Property Type Read-only Visible Value
BITSTREAM.CONFIG.DRIVEDONE enum false false Yes
-Pratham
Is there any reliability issue that would lead it to not be used?  It saved me from a PCB bug.  It works fine for me.
-m
I also wanted to add that the configuration user guide (UG470) for the 7-series says,
"The DriveDONE option is not supported for stacked silicon interconnect technology devices. External 330Ω resistor circuits work in the 7 series FPGAs as they have on previous generations."
This implies that it IS supported when using non-stacked parts.
-m
@maxbaker Like i told that is supported but you need not use it.
Same does UG says
-Pratham
