error:HDLCompiler:1654 when instantiating Synpfy-pro edf file to ise14.6 design
a usb3 ip core is synthesized with synplify-pro, an edf file is generated mmwave_DWC_usb3.edf.
when this edf file is instantiated to ise14.6 project, doing synthesis-XST, the error comes out:
Elaborating module <mac_sys_top>.
ERROR:HDLCompiler:1654 - "D:\zwq\proj_marvel\fpga_marvel\marvel_fpga_v7x690t\soc_phase2\intg\src\rtl\mac_sys\mac_sys_top.v" Line 272: Instantiating <inst_usb3_ctrler> from unknown module <mmwave_DWC_usb3>
Module mac_sys_top remains a blackbox, due to errors in its contents.
my synplify-pro version is F201203.
Try using -sd option in XST properties.
See the user guide for more information: http://www.xilinx.com/support/documentation/sw_manuals/xilinx14_6/xst_v6s6.pdf
I created a symbol of 1:2 decoder and instantiated in another schematic. On synthezing the schematic I am getting the error as
ERROR:HDLCompiler:1654 - "E:\PHD\phd_codes\alu16bit_25dec13\myadder\logicbit.vf" Line 44: Instantiating <XLXI_6> from unknown module <decoder1to2>
Please reply
