Visitor amb5l
fast inversion and distribution of a slow external clock
Hi all,
I need to invert an external clock and distribute globally, with minimum delay, in my 7-series design. The clock is too slow (1 MHz) for DLLs/PLLs. I have no specific delay target but the faster the better.
I have started with this: clock capable pin -> IBUFG -> LUT inverter -> BUFG -> global clock.
Is there a better way?
Teacher drjohnsmith
Re: fast inversion and distribution of a slow external clock
You have an interesting problem there,
not certain you can route through  a lut to the global clock without considerable / variable delay.
Can you cope with jitter ?
you could treat the 1 mhz clock as a signal,
   sample it to a much faster internal clock, say 200 MHz,
        observer all the normal clock crossing issues, but generate a single 200 Mhz pulse off the rising edge of the 1 MHz.
              you will have 5ns jitter on this, but the delay will be small and predictable.
Visitor amb5l
Good idea.
I need to latch an external data bus that is synchronous to the slow external clock - on the falling edge of course... My recipe for this will be: clock capable pin -> IBUFG -> BUFIO -> IDDR in OPPOSITE_EDGE mode (using Q2 output only). I will then work on the data and do everything else in a 100 MHz domain, having double sychronised the slow external clock and detected its falling edges.
Thankyou!
