how to get the right data from xadc ip when the xadc ip is instantiated ?
now I am using xadc, I have implemented using ps_xadc interfaec to acess the xadc via the linux driver which xilinx provides,and get the right data ; now I need to construct a system having a self_defined IP to get the xadc ip data via AXI STREAM,but when  the xadc is read from ps via axi  interface   ,I get the wrong data,
and what I want to know is :
1.  I know there are linux driver for xadc when ps_xadc interface is used ,and is there a independent linux driver just for axi_xadc interface when xadc is accessed from ps side ? can a example be provided ?
2. when xadc ip is instantiated, and operated via ps_xadc interface , is it same with using  axi xadc interface or not? can I get the xadc data from axi_stream interface correctly too ?
that is when xadc is  instantiated,a axi_xadc interface is created, the  dedicated ps_xadc can be used too on the same time ,right ?
the two interface can all  operate the xadc ip ,and have the same influence to the xadc ip ,right ?
Community Manager
Community Manager
Hi @microchip_zhang
This Xapp may be of interest to you : https://www.xilinx.com/support/documentation/application_notes/xapp1182_zynq_axi_xadc_mon.pdf
Sandy
Community Manager
Community Manager
Hi @microchip_zhang
Sandy
