how to invisible hierarchy of the design files in vivado 2016.4v
Hi I have encrypted my design  files using IEEE 1735 encryption and its successfully done and but am able to see the hierarchy of my design.so can i know how to prevent the visibilty of the design hierearchy??
Re: how to invisible hierarchy of the design files in vivado 2016.4v
check this tutorial it may help you
https://www.xilinx.com/support/documentation/sw_manuals/xilinx2014_1/ug946-vivado-hierarchical-design-tutorial.pdf
Thanks and Regards
Balkrishan
Hi @abhishek7,
I am not sure about what you can do. All the options are in UG1118 (link) p88. I have never tried all  but it seems to be the child_visibility option. Did you try with delegated for synthesis?
Hope that helps,
Florent
Florent
I Think child_visibility works only when the parent module is protected and child module is unprotected and what actions has to be taken to child module is defined by child_visibility...
Hi @abhishek7,
Did you try it?
I don't think there is more parameters available than in the UG...
Florent
Florent
thanks florent
I will give a try but as per ug1118 when you see the child_visibility parameter it is applicable in simulation,synthesis and implementation but i have a doubt that how can i define this parameter particularly in simulation or synthesis or implemenation can you tell me some syntax.
Hi @abhishek7,
To have it only in synthesis, it should be something like:
`pragma protect control child_visibility = (activity==simulation)? “allowed” : “delegated”
You should use the example from UG1118 (p90) for help
Florent
Florent
Hi florent i have tried but there is no change hierarchy is displayed
Hi @abhishek7,
I don't really know the standard so it is maybe not possible. Could you try:
`pragma protect control child_visibility = “delegated”
`pragma protect control runtime_visibility = “delegated”
Florent
Florent
here is my key file written as shown below
`pragma protect control xilinx_configuration_visible = "false"
`pragma protect control xilinx_enable_modification = "false"
`pragma protect control xilinx_enable_probing = "false"
`pragma protect control runtime_visibility = "delegated"
`pragma protect control child_visibility = (activity==simulation) ? "delegated" : "delegated"
`pragma protect control decryption=(xilinx_activity==simulation) ? "true" : "true"
`pragma protect end_toolblock = ""
hi Florent below configuration also not working
Hi @abhishek7,
Then if it is not working that means that there is no option to change the hierarchy names
Florent
Hi florent am not really worried about the name changes of the design sources i need to just make the hierarchy invisible.
Hi there,
While looking for solution to keey hierarchy invisible, I can see that you were having same problem I have now.
Just to check if you can keep hierachy off in vivado GUI?
James
