issue about an odd loopback
hi all
i am using virtex7 FPGA
for some reason,i want to do thing like this.
logic A generate a signal, through IOB, loopback to logic B
can this be realized?
i  have solved  this problem
use  IOBUF  like this
IOBUF IOBUF_inst
.O      (signal to logic_B),       // Buffer output
.IO     (d_edge),                     // Buffer inout port (connect directly to top-level port)
.I        (signal from logic_A), // Buffer input
.T       (1'b0)                          // 3-state enable input, high=input, low=output
use  IOBUF  like this
IOBUF IOBUF_inst
