output clock control
I need to control an output clock from an Artix-7 (stop it to have a specific number of clocks).
That's not how I would do it, but that's how it's specified...
I'm thinking of a BUFMRCE block then a standard OBUF. There will be serial data (1 bit) synchronous to that clock.
Any thoughts?
@johnvivm,
I create most of my output clocks using an ODDR primitive.  That allows me to duplicate the operation of the current clock, but with good fidelity.  It is a recommended solution.
Is this the sort of thing you are trying to do?
I'm a bit confused by your reference to a BUFGMRCE.  Are you talking instead about a clock going to the output drivers of the chip?
Dan
@johnvivm,
Dan
That's actually a good idea, DDR doesn't mean data has to be! I was stuck in the box this time.
Yes, the clock is to come out of the FPGA
