Visitor cangyisu
pmod voltage
Hi, I use a Nexys 7A FPGA board and feel concerned about the 12-pin pmod ports (see image):
1. What is the voltage value Pin1-4 and Pin 7-10 will provide? I get a voltage range 3.3V on oscilloscope but there is a DC offset (i.e. it's not 0~3.3V but something -2.2~1.1V)
2. I try to measure pin 6 and 12 (Vcc) and find that they don't provide 3.3V. Can you explain why?
Thank you!
Scholar u4223374
Re: pmod voltage
@cangyisu Where are you connecting the oscilloscope ground clip?
Voltage is relative. You should see 3.3V between pin 5 and pin 6 (or between pin 11 and pin 12). If you're just measuring from a floating ground to the VCC pin, then you'll get a more-or-less random value.
Community Manager
Community Manager
Re: pmod voltage
Hi @cangyisu
As this is a Digilent product you may get more useful responses on the Digilent Forum : https://forum.digilentinc.com/
Sandy
Scholar u4223374
Re: pmod voltage
