question about GTP byte alignment
HI,
In artix 7 GTP, i use a comma alignement of BC.
In mode 8b/10b ENCODING.
I don't understand one thing.
Alignment can be on the first or the second byte.
If it's in the second byte so data are not correct.
Is GTP control this problem automatically, or It's my job to code a vhdl control of this problem?
Best regards
Re: question about GTP byte alignment
How wide is your interface to the GTP?  20 bits?  If so, the GTP will not be able to tell between 16'hBCBC encoded as 20 bits and the opposite order for the bytes: 16'hBCBC.  You will have to take care of this.
Daniel
Are you setting the alignment position to even byte boundaries and not supplying the comma on even bytes?
My interface is 20 Bits, so, before recept data,  i need to check if data are in order?
But actually i don't check the order and my system work. Perhaps i'm lucky but i program my device a lot of time.
venkata, i don't understand your question.
Actually, i decode valid comma only (see attachement)
In the lane, the value comma (BC) is present until a information is transmit.
BCBC    BCBC    BCBC    BCBC   BCBC  ------  information  ------- BCBC  BCBC
In the header of the information transmit there a coma information, in this case BC transmit 3 times and one octet to dIstinguish the command :
EX : BCBC BCFD
When no information is send, there are no problem.
But when i receive the first header of a information i can receive :
BCBC BCFD or BCBC FDBC. In the second case all data are inversed.
So, is I need to check the order before transmit data to my code?
Best regard.
I see you have selected "Any byte boundary" for "Align to" option. With this option, the alignment can happen at any byte position.
If you select "even byte boundary" then you will get the alignment to even bytes always.
Check the comma alignment section in ug482 for more details about this aspects
I don't have "even byte boundary". I have any, two or three byte boundary so i suppose that you would say "two byte boundary".
I think that it's the solution of my question but i cannot verified them because actually i don't have problem of alignment.
I not understand why.
The gtp is configured in "any byte boundary" i verified them.
May be you need to re-adjust the byte order after the alignment is completed by GT.
