chenxuol
question about the VCCO of the HP bank
I'm using XC7K325T-900,DDR occupys two HP banks,I want to set the VCCO of the remaining HP bank to 1.8V ,and output a LVDS signal. is that valid?
iguo
If bank32 does not have any relationship, such as DCI cascade, with the two 1.5V banks, then it will have dependant Vcco.
LVDS_25 works in a HR bank but LVDS works in a HP bank, and this iostandard requires for a 1.8V Vcco. So yes, you can set LVDS in this 1.8V HP bank.
iguo
LVDS(1.8)can work in a 1.8V bank.
chenxuol
Thank you for your reply!
so VCCO of the last remaining HP bank is available for 1.8V?
iguo
Did you set DCI cascade or something in the HP bank? If not, why cannot set its VCCO to 1.8V?
chenxuol
DDR3 occupys bank33 and bank34,so the VCCO of these two banks is already set to 1.5V.
I need two LVDS output signals,and there is no 2.5V on the board,so I want to place the LVDS signals on bank32,and set the VCCO of bank32 to 1.8V.
iguo
