javad_2040
signal with High-z value can't update in process block!
Hi.
I design a system that contain SDRAM and spartan6 FPGA. I wrote SDRAM-Controller code for handle the SDRAM. In my code the defualt value of the SDRAM_DQ is High-z. My problem is that i send my data to SDRAM and recieved it but the received value is always 0xFF...FF.
the code is :
process(state_reg,Data_in)
begin
        SDRAM_DQ <= (others => 'z');
	case state_reg is
               when wr0 =>
                      SDRAM_DQ <= Data_in;
         end case;
end process;
data_out <= SDRAM_DQ;
seems the SDRAM_DQ signal wouldn't update and always has High-z value.
is anybody known that what is the problem?
jheslip
have you tried simulating?
Does the case statement ever get into the other cases?
