hermeselec
top marking of XC7A200T-1FBG484C
Regarding XC7A200T-1FBG484C, we found "1C" printed on the top mark,but the scanned result of the bar code shows "2I",how could this happen?does this mean this part is dual marking ,1C and 2I are the same?thx.
gnarahar
@hermeselec Where did you buy the part from? If from an Authorized distributor, do contact them and they will be able to help you out.
- Giri
If starting with Versal take a look at our Versal Design Process Hub and our Versal Blogs
hermeselec
This is bought from OEM excess stock,and can not trace back,that's why I put my quesiton here.
gnarahar
@hermeselec
Then I am afraid to say, we cannot guarantee if the part is genuine if not bought from Authorized distributor due to the fake market out there. The Top Marking and Bard Code should match on the parts.
- Giri
