Observer saxilix123
transmit clock as data
Hi all. I have 4 adcs . I sampled with 100 MHZ clock. I want to do some process of ADC data on a board and after that transmit datas and clocks to another board and do some others process on them. Can I use SFP module to transmit them? in other word how can I transmit clock as data without using IO pinout. please help me.
Re: transmit clock as data
Hi @saxilix123
Is any FPGA GPIO pin is connected to SFP module?  If Yes then you can transmit/forward the clock to the other board .
the clock path in this case is
Clock you want to forward to the downstream device  ->  ODDR  (connect output to the GPIO pin)
 ODDR is to  keeps the duty cycle and provides the best possible path[Assign Logic '1'  to D1 and  Logic '0' to D2. [This way, the output of the ODDR will generate a high at posedge of the clock and a low at negedge of the clock]
Please refer to the 7 series FPGA Libraries Guide for description and instantiation of these primitives
https://www.xilinx.com/support/documentation/sw_manuals/xilinx2018_2/ug953-vivado-7series-libraries.pdf
Reply if you have any queries, Give Kudos and Accepts as Solution
Reply if you have any queries, give kudos and accept as solution
Observer saxilix123
Hi pthakare
SFP is connected to GTX PIN. At now I constract a packet that taransmite and recieve data with 10G rate in sfp module. I want to transmit data and it's clock without any additional pin. IS there any convinient way for this problem?
Observer saxilix123
I'm waiting for any help
