Newbie tomy222
using DFF to implement fifo
Hi all.
i am confused with the fifo design
if i use flip flop to implement fifo, the condition generating full signal is not same as sram based fifo?
Using flip flop we can read and write same address at the same time. So , i think the condition generating full signal is not same as sram based fifo. Am i correct?
Thanks!
Re: using DFF to implement fifo
Hi why would you want to consume large amounts of flip flops when there is a proven FIFO there to use?
Full will be generated by the FIFO when the write pointer reaches the end of the FIFO
Can you show us the rtl code you use to make this FIFO?
