using XADC in Zynq 7015, from PS and PL
I have a Zynq design which runs petalinux, and I make use of the Linux XADC device to monitor the internal temp. It works fine. This must use the PL side because it does not require any PS design.
I would like to use the spare XADC channels to monitor an analogue signal on the PS side. I was considering making an AXIS stream with the wizard.
Will using the XADC in the logic design effect the Linux device driver? Or can this work independently?
I will need a PCB change to try this and have the option of an external ADC connected by SPI
Re: using XADC in Zynq 7015, from PS and PL
Hi @davewarren
When the XADC is not instantiated in the PL design it will run in default sequencer mode.
which means it will monitor temperature and supplies and constantly cycle through these channels.
There are several ways to interface to it.
In Zynq, it is important to understand there 2 cases.
1. No XADC instantiated in the PL Design.
2. XADC is instantiated in the PL Design.
In case 1 there is a dedicated PS-XADC connection via the APB bus. The red path in the image.
When you want to monitor an external channel or an internal channel not in the default sequence you will need to use case 2 and connect the PS to the XADC via the AXI4Lite interface.
In this case you can use the XADC wizard to set this up.
Hi @davewarren
Thanks for the reply.
I guess if I want to instantiate it in the PL so I can change the sequence and monitor the external voltage the Linux driver will no longer be able to read the temp.
Hi @davewarren,
I am not a linux expert, but when i need to do some basic SW for XADC when it is instantiated in the PL for Zynq I have a reasonably simple baremetal example that I always use as a start point. It uses a driver called xsysmon.c
#include <stdio.h>
#include "platform.h"
#include "xil_printf.h"
#include "xil_types.h"
#include "xsysmon.h"
static XSysMon XADCMonInst;
int main()
XSysMon_Config *ConfigPtr;
XSysMon *XADCInstPtr = &XADCMonInst;
int Status_ADC;
u32 TempRawData;
float TempData;
u32 PLVccintRawData;
float PLVccintData;
init_platform();
ConfigPtr = XSysMon_LookupConfig(0);
if (ConfigPtr == NULL) {
return XST_FAILURE;
Status_ADC = XSysMon_CfgInitialize(XADCInstPtr,ConfigPtr,ConfigPtr->BaseAddress);
if(XST_SUCCESS != Status_ADC){
print("ADC INIT FAILED\n\r");
return XST_FAILURE;
xil_printf("Hello World\n\r");
xil_printf("Check Temperature\n\r");
TempRawData = XSysMon_GetAdcData(XADCInstPtr, XSM_CH_TEMP);
TempData = XSysMon_RawToTemperature(TempRawData);
xil_printf("Raw Temp %lu \n\r", TempRawData);
printf("Real Temp %.1f \n\r", TempData);
xil_printf("Check VCCINT\n\r");
PLVccintRawData = XSysMon_GetAdcData(XADCInstPtr, XSM_CH_VCCINT);
PLVccintData = XSysMon_RawToVoltage(PLVccintRawData);
xil_printf("Raw VCCINT %lu \n\r", PLVccintRawData);
printf("Real VCCINT %.2f \n\r", PLVccintData);
cleanup_platform();
return 0;
Thanks again, that looks like a good starting point, of course in Linux I would have to Mmap to access the addresses from user space, but that should be ok.
indeed once it is on the AXI bus it is going to invalidate the addressing on the PS-XADC interface.
Keith
