vivado error in timming analysis
There is a large setup violation of -2.258 ns between pwm_out_reg/C (clocked by sys_clk_pin) and pwm_out (clocked by sys_clk_pin). Large setup violations at the end of those stages might be difficult to fix during the post-placement implementation flow and could be the result of non-optimal XDC constraints or non-optimal design architecture
some background and you r design files as an attatchment please
