what is the major difference between kintex-7 and kintex ultrascale fpgas?
Re: what is the major difference between kintex-7 and kintex ultrascale fpgas?
Logic density, performance and cost.
Read datasheets for more details.
https://www.xilinx.com/products/silicon-devices/fpga/kintex-ultrascale.html
https://www.xilinx.com/products/silicon-devices/fpga/kintex-7.html
FPGA enthusiast!
All PMs will be ignored
hi @deepak1991,
kintex-7
XC7K70T
XC7K160T
XC7K325T
XC7K355T
XC7K410T
XC7K420T
XC7K480T
Logic Cells
65,600
162,240
326,080
356,160
406,720
416,960
477,760
DSP Slices
240
600
840
1,440
1,540
1,680
1,920
Memory
4,860
11,700
16,020
25,740
28,620
30,060
34,380
GTX Transceivers
8
8
16
24
16
32
32
I/O Pins
300
400
500
300
500
the ultra scale device is
XCKU025
XCKU035
XCKU040
XCKU060
XCKU085
XCKU095
XCKU115
System Logic Cells (K)
318
444
530
726
1,088
1,176
1,451
DSP Slices
1,152
1,700
1,920
2,760
4,100
768
5,520
Block RAM (Mb)
12.7
19.0
21.1
38.0
56.9
59.1
75.9
16.3Gb/s Transceivers
12
16
20
32
56
64
64
I/O Pins
312
520
520
624
676
The difference is kintex-7 is 28 nm device where as the ultra-scale device is 20nm , if we compare the table we can that ultra-scale device has better  architecture  to build system (system logic cells  Vs logic cells ) and more transceiver support .
Thanks & Regards,
chandra sekhar
Please mark the post as an answer "Accept as solution" in case it helps to resolve your query.
Helpful answer -> Give Kudos
Chandra sekhar
Kindly note- Please mark the Answer as "Accept as solution" if solution provided is helpful.
Hi chandra shekhar,
           Thanks for reply.But i want know why cost wise kintex-7 having more cost than kintex ultrascale FPGA with equivalent resources and performance.
Akon
Can please let me know the part number which you're looking at ...
Chandra sekhar
Cost is not only depends upon size of FPGA it also depends upon many business factors like volume of production , life span etc.
For cost/Device selections issues help please contact Xilinx/Distributors Field Application Engineers (FAE/DFAE). They will help you in better way for device selection. You can get contact details of them from the following link http://www.xilinx.com/about/contact/sales-offices.html . (That link can guide to http://www.xilinx.com/about/contact/authorized-distributors.html )
Newer generations are normally cheaper for the same resources and performance. If they got more expensive each time then (a) nobody would ever move to the new generations, and (b) any modern chip would cost a fortune.
The XC3142A cost $14.25 (if you bought 100 units) in 1997. It contained 288 4-input LUTs and 288 flip-flops (in the main logic; there were a further 192 in the I/O buffers). Assuming that prices scaled linearly with number of LUTs (never mind the higher speed and improved functionality) a Zynq 7020 (53,200 LUTs) would cost $2632 (1997 dollars). Converting to 2017 dollars brings that up to just over $4000 today. In fact Digikey will sell you a Zynq 7020 for just under $120, and I suspect that if you buy lots of them the cost is vastly lower (since Digilent will sell you a Zynq 7020 board for under $100).
