7-series GTX CML I/O standard issue
Hello
Xilinx transceivers uses CML IOSTANDARD.
In xilinx 7-series example design, have fixed GTREFCLK location, but other pins not configured(txdata/rxdata)
In below I/O table, the txdata and rxdata pins aren't configured CML I/O standard.
How do i can configured CML I/O standard?
Re: 7-series GTX CML I/O standard issue
Only the serial transceiver pins need to be constrained(txp,txn,rxp and rxn),parallel data(txdata and rxdata will be interfaced internal to the FPGA and doesn't need any IO constraints)
They can be done by specifying the pins or the GT location as done in your case below(GTXE2_CHANNEL_X0Y4)
As it supports only one IO standard it will set to correct standard by default.
Satish
Satish
Thanks for your help!!
