7-series GTX TXN/TXP and RXN/RXP issue
Hello
I want to used 7-series transceiver IP.
Why does TXN/P connect RXN/RXP?
Scholar u4223374
Re: 7-series GTX TXN/TXP and RXN/RXP issue
@quincyq2003 That makes sense. You want the transmitter on one board (TXN/TXP) connected to the receiver (RXN/RXP) on the other board. That way you can transmit data from one and receive it on the other.
If you connected TXN/TXP on one board to TXN/TXP on the other board then they'd both be trying to drive the same lines, and damage may occur. If you connected RXN/RXP on one board to RXN/RXP on the other board then neither could drive the lines (because the receiver cannot provide an output); you wouldn't cause any damage but you also couldn't transmit any data.
Scholar u4223374
Where does TXN/P connect to RXN/P? Which document are you looking at?
Hello @u4223374
In PG-168 7 Series FPGAs Transceivers Wizard v3.6 document page 129 description.
https://www.xilinx.com/support/documentation/ip_documentation/gtwizard/v3_6/pg168-gtwizard.pdf
Scholar u4223374
Hello @u4223374
If FPGA TXN/TXP connect to FPGA  RXN/RXP, have any benefit?
If FPGA TXN/TXP not connect to FPGA  RXN/RXP, have any impact?
Scholar u4223374
The document you've referred to is explaining how to connect one FPGA (FPGA1) to another FPGA (FPGA2).
If you do connect FPGA1 TXN/TXP to FPGA1 RXN/RXP (ie one FPGA connected to itself) then you have created a loop-back, which is useful for testing signal integrity but has no practical purpose.
If you do connect FPGA1 TXN/TXP to FPGA2 RXN/RXP (ie one FPGA connected to another FPGA) then you can send data from FPGA1 to FPGA2.
If you don't connect FPGA1 TXN/TXP to FPGA1 RXN/RXP (ie one FPGA not connected to itself) then this is how a circuit would normally be designed - as above, there's no practical purpose to connecting them.
If you don't connect FPGA1 TXN/TXP to FPGA2 RXN/RXP (ie one FPGA not connected to another FPGA) then obviously you can't send data between them. You need to connect them if you want to send data.
