Observer sunyonglai
AXI interconnect IP sync CLK
Hi,everyone!
In AXI interconnect  IP,the  NTERCONNECT_ACLK  must be mcb_clk?  And how to set the slave ratio to NTERCONNECT_ACLK  ? 1:1,2:1,1:2?
When in async mode , the core can run right,but in sync mode can not? Why?
thanks!
mcb_clk  is 100Mhz.
Re: AXI interconnect IP sync CLK
Hi @sunyonglai,
In your bd, in the top, you should have a link like "run connection automation". Click on it, it will connect everything for you.
Florent
Florent
