Newbie utpalrathod
Can GPIO of FPGA be defined as clock input and output?
Can I use GPIO as clock Input and Output to synchronize my external devices.
e.g. Can Pin number E14 and E15 of Kintex 7 FPGA be defined as clock to sync external device?
Utpal Rathod
Re: Can GPIO of FPGA be defined as clock input and output?
Hi @utpalrathod
It is recommended to use CCIO (clock capable IO) pins for clock input or output ports you wish to synchronize with any external devices.
Which package/ part of Kintex you are targetting? Here is the helpful link for you.
https://www.xilinx.com/support/package-pinout-files/kintex-7-pkgs.html
Rohit
Hi @utpalrathod
I am not sure about input but you can use GPIO to forward the clock i.e
Clock you want to forward to the downstream device  ->  ODDR  (connect output to the GPIO pin)
 ODDR is to  keeps the duty cycle and provides the best possible path[Assign Logic '1'  to D1 and  Logic '0' to D2. [This way, the output of the ODDR will generate a high at posedge of the clock and a low at negedge of the clock]
Please refer to the 7 series FPGA Libraries Guide for description and instantiation of these primitives
https://www.xilinx.com/support/documentation/sw_manuals/xilinx2018_2/ug953-vivado-7series-libraries.pdf
Please reply if you have any queries , Give Kudos and Accept as Solution
Reply if you have any queries, give kudos and accept as solution
