Clocking issue with a design including xc7k410t FFG900
Dear all,
I am using Vivado 2017.3 and a Sundance board including a XC7K410T FFG900 Xilinx FPGA.
I have a block design that I have instantiated two clock signals in it, ref_clk that is connected to the PCIe reference clock pin of a AXI Memory Mapped to PCI Express module. Both clock signals are defined by  defined by Tcl command for interface clock creation, and the sys_clk that is connected to the MIG 7 Series as shown below.
My Tcl commands for clock generations are as follows:
# ---------- SYS_CLK for MIG 7 Series DDR3 SDRAM
create_bd_intf_port -mode Slave -vlnv xilinx.com:interface:diff_clock_rtl:1.0 sys_clk
connect_bd_intf_net [get_bd_intf_pins mig_7series_1/SYS_CLK] [get_bd_intf_ports sys_clk]
# ------------ ref_clk for PCIe module
create_bd_intf_port -mode Slave -vlnv xilinx.com:interface:diff_clock_rtl:1.0 ref_clk
connect_bd_net [get_bd_pins ref_clk_buf/IBUF_OUT] [get_bd_pins axi_pcie_0/REFCLK]
and here are the constraints that I have written in an XDC file for both clock siugnals:
# --- ref_clk (for PCIe)
set_property PACKAGE_PIN U8 [get_ports {ref_clk_clk_p[0]}]
set_property PACKAGE_PIN U7 [get_ports {ref_clk_clk_n[0]}]
# --- SYS_CLK
set_property PACKAGE_PIN K28 [get_ports {sys_clk_clk_p}]
set_property PACKAGE_PIN K29 [get_ports {sys_clk_clk_n}]
While Placement design the process fails and I receive the following Placement Error [Place 30-172]
[Place 30-172] Sub-optimal placement for a clock-capable IO pin and PLL pair. If this sub optimal condition is acceptable for this design, you may use the CLOCK_DEDICATED_ROUTE constraint in the .xdc file to demote this message to a WARNING. However, the use of this override is highly discouraged. These examples can be used directly in the .xdc file to override this clock rule.
	< set_property CLOCK_DEDICATED_ROUTE ANY_CMT_COLUMN [get_nets ublaze_i/mig_7series_1/u_ublaze_mig_7series_1_1_mig/u_ddr3_clk_ibuf/sys_clk_ibufg] >
	ublaze_i/mig_7series_1/u_ublaze_mig_7series_1_1_mig/u_ddr3_clk_ibuf/diff_input_clk.u_ibufg_sys_clk (IBUFDS.O) is locked to IOB_X0Y174
	 ublaze_i/mig_7series_1/u_ublaze_mig_7series_1_1_mig/u_ddr3_infrastructure/plle2_i (PLLE2_ADV.CLKIN1) is locked to PLLE2_ADV_X1Y1
	The above error could possibly be related to other connected instances. Following is a list of
	all the related clock rules and their respective instances.
	Clock Rule: rule_gclkio_bufg
	Status: PASS
	Rule Description: An IOB driving a BUFG must use a CCIO in the same half side (top/bottom) of chip
	as the BUFG
	 ublaze_i/mig_7series_1/u_ublaze_mig_7series_1_1_mig/u_iodelay_ctrl/clk_ref_200.u_bufg_clk_ref (BUFG.I) is provisionally placed by clockplacer on BUFGCTRL_X0Y7
	Clock Rule: rule_gclkio_mmcm_cdr_bb
	Status: PASS
	Rule Description: An IOB driving an MMCM must both be in the same column clock regions if CLOCK_DEDICATED_ROUTE=BACKBONE
	is set
	 ublaze_i/mig_7series_1/u_ublaze_mig_7series_1_1_mig/u_iodelay_ctrl/clk_ref_mmcm_gen.mmcm_i (MMCME2_ADV.CLKIN1) is provisionally placed by clockplacer on MMCME2_ADV_X0Y6
	Clock Rule: rule_mmcm_bufg
	Status: PASS
	Rule Description: An MMCM driving a BUFG must be placed on the same half side (top/bottom) of the device
	 ublaze_i/mig_7series_1/u_ublaze_mig_7series_1_1_mig/u_iodelay_ctrl/clk_ref_mmcm_gen.mmcm_i (MMCME2_ADV.CLKOUT1) is provisionally placed by clockplacer on MMCME2_ADV_X0Y6
	 ublaze_i/mig_7series_1/u_ublaze_mig_7series_1_1_mig/u_iodelay_ctrl/clk_ref_300_400_en.clk_ref_400.u_bufg_clk_ref_400 (BUFG.I) is provisionally placed by clockplacer on BUFGCTRL_X0Y16
	Clock Rule: rule_mmcm_mmcm
	Status: PASS
	Rule Description: An MMCM driving an MMCM must be in the same CMT column, and they are adjacent to
	each other (vertically), if the  CLOCK_DEDICATED_ROUTE=BACKBONE constraint is NOT set
	 ublaze_i/mig_7series_1/u_ublaze_mig_7series_1_1_mig/u_iodelay_ctrl/clk_ref_mmcm_gen.mmcm_i (MMCME2_ADV.CLKFBOUT) is provisionally placed by clockplacer on MMCME2_ADV_X0Y6
	 ublaze_i/mig_7series_1/u_ublaze_mig_7series_1_1_mig/u_iodelay_ctrl/clk_ref_mmcm_gen.mmcm_i (MMCME2_ADV.CLKFBIN) is provisionally placed by clockplacer on MMCME2_ADV_X0Y6
	Clock Rule: rule_pll_bufhce
	Status: PASS
	Rule Description: A PLL driving a BUFH must both be in the same horizontal row (clockregion-wise)
	 ublaze_i/mig_7series_1/u_ublaze_mig_7series_1_1_mig/u_ddr3_infrastructure/plle2_i (PLLE2_ADV.CLKOUT3) is locked to PLLE2_ADV_X1Y1
	 ublaze_i/mig_7series_1/u_ublaze_mig_7series_1_1_mig/u_ddr3_infrastructure/u_bufh_pll_clk3 (BUFH.I) is provisionally placed by clockplacer on BUFHCE_X1Y12
	Clock Rule: rule_bufh_bufr_ramb
	Status: PASS
	Rule Description: Reginal buffers in the same clock region must drive a total number of brams less
	than the capacity of the region
	 ublaze_i/mig_7series_1/u_ublaze_mig_7series_1_1_mig/u_ddr3_infrastructure/u_bufh_pll_clk3 (BUFH.O) is provisionally placed by clockplacer on BUFHCE_X1Y12
	Clock Rule: rule_bufhce_mmcm
	Status: PASS
	Rule Description: A BUFH driving an MMCM must both be in the same clock region
	 ublaze_i/mig_7series_1/u_ublaze_mig_7series_1_1_mig/u_ddr3_infrastructure/gen_mmcm.mmcm_i (MMCME2_ADV.CLKIN1) is locked to MMCME2_ADV_X1Y1
	Status: PASS
	 ublaze_i/mig_7series_1/u_ublaze_mig_7series_1_1_mig/u_ddr3_infrastructure/gen_mmcm.mmcm_i (MMCME2_ADV.CLKFBOUT) is locked to MMCME2_ADV_X1Y1
	 and ublaze_i/mig_7series_1/u_ublaze_mig_7series_1_1_mig/u_ddr3_infrastructure/u_bufg_clkdiv0 (BUFG.I) is provisionally placed by clockplacer on BUFGCTRL_X0Y1
I have tries lots of scenarios and methods to solve this problem but it still does exist. I am really confused! Can anyone help me to solve this issue, please?
Kind helps are in advance appreciated.
Bests,
Re: Clocking issue with a design including xc7k410t FFG900
@msdarvishi,
The problem goes around the Sys_clk that you have considered for the DDR3. Please just use the Create Interface Port option for DDR3 SYS_CLK in Block design by right-clicking on this port and choose Create Interface Port. Then, DO NOT constraint this port in your XDC file becsuse the SYS_CLK ports are already constrained and connected in  the KC705 board file. It will solve you problem and the placer will pace without ant warning.
God luck,
Daryon
Any comment, suggestion or hint??
Msdarvishi,
Have you tried constraining your PLL to be in the same bank as your input clock sent to the memory interface? Have you checked our site for ARs like the one below that seem to cover this?
https://www.xilinx.com/support/answers/40603.html
regards,
T
@msdarvishi,
God luck,
Daryon
