Observer engineer_wu
Could I program the output of the VC707 to be 3.3v?
I have a VC707 board. I need to use this board to generate some control signals to control another custom board. The control signals come out from FPGA through the FMC2. The custom board needs a 3.3v logic ‘1’ level. I would just like to know whether I can program those pins on FMC2 so that the logic ‘1’ level on those pins is 3.3v?
Could anyone give some suggestions?
Thank you very much
Xun
Re: Could I program the output of the VC707 to be 3.3v?
FMC pins in VC707 is connected to HP banks.
For more details you can check the board user guide.
http://www.xilinx.com/support/documentation/boards_and_kits/vc707/ug885_VC707_Eval_Bd.pdf
FMC interface is powered by Vadj which by default is 1.8v.
So the Vadj cannot be changed to 3.3V, so you will not be able to drive logic 1 at 3.3v.
--Krishna
The voltage ranges supported for VADJ  of VC707 can be found in http://www.xilinx.com/support/answers/51770.htm
