Visitor danielsulik
ERROR:Place:1073 - Placer was unable to create RPM[GTXE_CHANNEL_RPMs] for the component
I am targetting VC707 SFP+ interface and having difficulties to build the design when using my ucf setting.
Using ISE14.2.
I created  ten_gig_eth_pcs_pma_v2_1 from coregen and wired up my application to the examle generated by coregen.
PCS/PMA + GTX
My ucf is as follows:
CONFIG PART = xc7vx485t-ffg1761-2;
NET REFCLK_P LOC = AK34 | IOSTANDARD=LVCMOS18; # Bank 14 VCCO - VCC1V8_FPGA - IO_L12P_T1_MRCC_14
NET REFCLK_N LOC = AL34 | IOSTANDARD=LVCMOS18; # Bank 14 VCCO - VCC1V8_FPGA - IO_L12N_T1_MRCC_14
NET RESET LOC = AV39 | IOSTANDARD=LVCMOS18; # Bank 15 VCCO - VCC1V8_FPGA - IO_L11N_T1_SRCC_15
NET RX_N  LOC = AL5 | IOSTANDARD=LVCMOS18;
NET RX_P  LOC = AL6 | IOSTANDARD=LVCMOS18;
NET TX_N  LOC = AN1 | IOSTANDARD=LVCMOS18;
NET TX_P  LOC = AN2 | IOSTANDARD=LVCMOS18;
In map stage I get the follwing error.
   component
   i_ten_gig_eth_pcs_pma_v2_1_example_design/ten_gig_eth_pcs_pma_block/gtwizard_
   10gbaser_i/gt0_gtwizard_10gbaser_gt_i/gtxe2_i of type GTXE_CHANNEL for the
   following reason.
   The reason for this issue:
   All of the logic associated with this structure is locked and the relative
   placement of the logic violates the structure. The problem was found between
   the relative placement of GTXE_CHANNEL
   10gbaser_i/gt0_gtwizard_10gbaser_gt_i/gtxe2_i at site GTXE2_CHANNEL_X1Y2 and
   OPAD tx_n at site OPAD_X1Y2.  The following components are part of this
   structure:
      GTXE_CHANNEL
      OPAD   tx_n
I recon the problem is GTX location. Is coregen generated example tied up to a specific GTX location?
How to change it if so.
Dan
Visitor danielsulik
Re: ERROR:Place:1073 - Placer was unable to create RPM[GTXE_CHANNEL_RPMs] for the component
Problem, solved.
Documentation (ug885_VC707_Eval_bd.pdf, page 36) specs wrong pins for GTX module.
Correct pins are
AL5 = SFP_RX_N,
AL6 = SFP_RX_P,
AM3 = SFP_TX_N,
AM4 = SFP_TX_P
