Visitor avi833
GTX GTHE3 CHANNEL TX direction. tx_usrclk_out output
i tried to implement TX direction on "v_smpte_uhdsdi_gtwiz" (from mange ip)
my ref clk gth_qpll0_ref_clk_p_in = 148.5Mhz
drpclk = 148.5Mhz
tx_mode = '01' - SD-SDI
tx_m_in = 1
gth_wiz_treset_all_in = asserted to '1' more then 1 cycle of drp clock
qpll0_lock = 1
but tx_userclk_out ouput is '0'!! - need to be 148.5Mhz
i dont why. if someone can help me with this. i will be more than happy [-:
Re: GTX GTHE3 CHANNEL TX direction. tx_usrclk_out output
I see that Qpll lock and gt reset done is not asserted in the simulations.
You need to simulate for longer time.
Satish
Visitor avi833
i simulate it for 5ms
and its ths same
Is this with the core generated test bench or your own.
Satish
Visitor avi833
my test bench.
very simple. only generator clk, rst, and tx_mode.
Please try simulating the example design to confirm the required reset procedure.
